And the car is running very rich. Even with the garage door open I nearly choke to death on the fumes. It's the passenger side O2 sensor that's reading 2.55 volts on the Techtom. I even just replaced that sensor with a new one and am still getting the same reading.I get an all clear code 55 from the ECU. I don't see how the harness wiring could be bad as it is still basically new with barely 500 miles on it. I did plenty of searching and found posts from people with the same problem, but no one ever posted a solution!! Any suggestions are much appreciated.
Later,
B.U.C.K.Y.: Biomechanical Unit Calibrated for Killing and Yardwork
